Re: HP 41cx Survey module Message #2 Posted by Randy on 2 May 2006, 1:15 p.m., in response to message #1 by Don Lovett
[xeq] [alpha] SIZE [alpha] 040
should fix your problem. CX's default to a small number of numeric registers, less than the survey routines require. Resizing memory will fix it. The CV does not has the issue as it alocates more memory to register usage by default.
Edited: 2 May 2006, 1:18 p.m.
