WOODSTOCK Dis-assembling Message #1 Posted by Mike T. on 27 Apr 2006, 1:12 p.m.
Having recently aquired an HP25 (my first WOODSTOCK) I was wondering how best to take it apart. I've seen several postings here on how to dis-assemble a SPICE series calculator but nothing on dis-assembling a WOODSTOCK series machine.
Apart from just plain curiosity it seems like the display is actually sloped _away_ from the user inside and is difficult to read unless you move your head directly overhead, so unless this is normal I though I might try to find out why?
There are also some marker pen and glue marks on body of the calculator which I might try removing with a suitable solvent - are there any to AVOID using?
I hadn't realised just how compact the HP25 is, it is a real little marvel given the technology available at the time, interestingly it also seems to run noticably faster than either my HP33C or HP34C.
Now has anyone got a (cheap) UK battery charger :-) !
Mike T.
Edited: 27 Apr 2006, 1:26 p.m.
