Re: HP48GX and SPICE 48 Message #6 Posted by Raymond Del Tondo on 11 Apr 2006, 5:03 p.m., in response to message #5 by Cliff Vrla
the browser libraries from James Donnelly,
Title Browser, Data Browser, and Tool Library,
which make up an important part of the user
interface of the Sparcom cards,
are mostly written in 'conservative' SysRPL.
This means the libs use supported entry points,
and should work on any HP-48 revision.
As far as I can see, the other libs,
which make up the SPICE functionality,
are written in a mixture of UserRPL and SysRPL,
with most parts in UserRPL.
So there's a chance that unsupported entries were used.
And if I recall it right,
there also was a problem with the diagram display
when running on the G series calcs,
but I'm not sure what it was in particular right now.
I once (many years ago) started to convert
the UserRPL code SysRPL, because the SPICE48
application was sooo sloooow.
But then other tasks kept my attention;-)
Raymond
