Re: HP-97 Card Reader - Only works sometimes Message #2 Posted by Randy on 27 Mar 2006, 7:22 p.m., in response to message #1 by jbssm
Backing off on all three screws several turns should force the contacts to go open. If that doesn't work, take the four nylon balls out and and check for flatness before you go bending anything. If they sit flat against the plate, that's not the problem. The screws do interact with each other and sometimes you just need to reset all and start over. Great fun isn't it?
