Re: An Updated Version of the 15c Would Make Money...? Message #2 Posted by db (Martinez, California) on 27 Jan 2007, 9:28 p.m., in response to message #1 by Tom Salmon
You have nothing to loose. Trying to return ebay purchases is a real drag most of the time. Unless it's someone like Mike, odds are they are selling junque they found at the flea that even I passed up. They don't want it back.
Remember: a couple of hours soaking and cleaning in +/- 70% alcohol is a good method but make sure you get everything off the screen when you are done or it will etch the clear plastic. I have had good luck with MG Chemicals "Super Contact Cleaner" on the keys. I think that most tv tuner cleaners will be fairly safe to use on the 41's materials because since they are a one-size-fits-all product; they shouldn't have anything that dissolves common plastics. Your mileage may vary.
I have cleaned a dead key from the back, using the (Randy's? David's?) tiny wire-brush-through-the-hole method. It had acted like your's and it is almost as good as new now. A lot of goop can kill the clickness.
A lot of dads get their kid a 33s.
YOU are a class act my man.
BTW: Here is a link to see how a great engineer uses the
Universal Solvent http://echosphere.net/star_trek_insp/insp_alcohol.png.
Edited: 27 Jan 2007, 11:27 p.m.
