hp psc2175 Message #1 Posted by sandor galas on 19 Jan 2007, 5:49 a.m.
Please, if you can help me:
I have a HP PSC2175 all-in-one and has a big problem: it can't find 0 (zero) position of scanner head, so engine keep runing and after a while show message: "Scanner failure. Press..."
Please, if you have any solution, help me.
Same problem I have with HP PSC750. The main difference is that engine stop but message is the same: "Scanner failure".
Thank you!
