Re: HP67 Wear--the final verdict Message #8 Posted by Albrecht Brenner on 23 Jan 2007, 2:09 p.m., in response to message #1 by Les Wright
Hello all,
I got a HP 67 today. Got it from ebay (Germany) at a moderate price. The calculator arrived in a perfect cosmetic condition, as if it was put into an ultrasonic cleaner as a whole... Battery is missing an minor signs of corrosion at the contacts are visible.
The conversion label on the backside is not damaged. Either the calculator has never been opened, or the label was replaced by a new one.
However, the screws blow the rubber feet were not fully tightened, elevating visually the rubber. At a first look, the display was working ordinarily, including the exponents. But when I tightened the bolts, its brightness faded and then intermitently came back, depending on the state of these two bolts.
Key clicks seem acceptable, but some of the keys do not respond at all, some give a faulty response, 9 on the display, when 8 has been pressed.
As no battery is available, I can't say anything about the card reader.
I bought this calculator, because I used to have one in my students time and I earned my first money with its help (producing results of lengthy calculations in a short time with the help of the programming facility). I would like to have it fully operational. Could anybody asess the chances for a reconstruction or offer help of anbody, to could do the mecanical and electronic work, as me myself do not have any experience in this field.
Best regards
Albrecht Brenner
