Re: Can anyone help me fix my HP 41CV? Message #2 Posted by Les Wright on 21 Dec 2006, 1:33 p.m., in response to message #1 by Bob
If it is fixable, Randy at FixThatCalc.com will work a miracle for you. He did for me.
Pros: Excellent, thorough, painstakingly careful restoration. My old 41CV was destined for the recycle bin, but it is now good as new. Rates also very reasonable--for US customers his flat rate is $79 and that usually does the trick for most work. If not, he will let you know.
Con (if you can call it that): Randy is so good that he always runs a little bit of a backlog, so much so that he has joked with me about proposed repairs that he doesn't need any more business ;) However if you can wait for a few weeks for turn around, you should find it worth it.
If you don't know much about calculator repair I wouldn't attempt the repair yourself, especially if there has been battery leakage.
Les
