Re: HP-10B repairable? Message #2 Posted by Randy on 28 Nov 2006, 5:09 p.m., in response to message #1 by Mike (Stgt)
Well used? As in beaten up badly? If it has any loose, wobbling keytops, it's a lost cause. Loose keys on a 48/Pioneer = Paperweight.
What's the S/N? The noisy key is common on later Indonesian units.
If none of the above, it's probably a leaky keyboard. Might have something to do with the Campari. Several cycles in an ultrasonic cleaner in warm distilled water (sans batteries of course) might do the trick. Give it at least a day, two is better in a warm place to dry. It might return to useful status. Might not.
