Re: HP10 (Classic) Paper ? Message #2 Posted by David Smith on 25 Nov 2006, 5:48 p.m., in response to message #1 by Olivier TREGER
Well, for stores most office supply stores like Staples have it in their catalog/warehouse but not stocked in the stores. The last time I bought it (at an Office Max) it took them a day to get it in. It is 1.5 inch / 38mm wide, preferably coreless (or at least not attached to the core).
If you are careful, you can also cut down wider rolls with a razor saw. I cut mine a little wide and then squared up the end with a table sander.
