Card reader repair in a HP-67 Message #1 Posted by jbssm on 23 Nov 2006, 1:45 p.m.
Hi all,
first of all, I must say this is a very technical problem and perhaps really difficult to solve ... still I'll try cause this seems the best form to try and find an answer.
I'm trying to repair the card reader of a HP-67 calculator.
This is what I already did:
1 - Cleaned all the gummy well remains
2 - Replaced the gummy well by 2 O-rings
3 - Revised the shaft mechanism
4 - Since after the above is was still not working, I also calibrated the screws in the golden metal plates so that they are on with a card inserted and off without a card
Still, although the card passes, I always get an error.
The only strange thing I notice is that almost at the end of the card passing, I hear the motor still running for more about 0.1 sec. before it actually stops ... I don't know if this is normal or not since I think it also happens in working units when you put a bad card in and gives error on reading.
Now, is there someone that can help me solve this problem?
Edited: 23 Nov 2006, 1:46 p.m.
