HP-71B problem has me stumped Message #1 Posted by Mike on 1 Nov 2006, 4:21 p.m.
I know a bit about the 71B but I have two that have me stumped. I have a dead mint 2CCCC 71B that was working, then became kind of intermittent, and then just stopped working all together.
When I say intermittent, I mean it would work and then if moved would shut off. Movement seemed to be the problem. Or bad connection type problem. I could tap the 71B and it would come back on. Now it doesn't come on at all. At first I thought it was the connector between the two halves. But I swapped that connector with another unit and it didn't fix the problem. I have also swapped the back half and the problem isn't with that half.
Now, I find that I have another mint 71B that had exactly the same behavior. Was working and then suddenly stopped the same way. I'm stumped.
I wouldn't mind so much, if this were not happening to mint 71Bs.
The problem is kind of hard to find because these are the plastic back, you can't test them when opened. Maybe I need to fabricate some sort of flexible cable to allow it to be opened and still function. Anyway, I was wondering if anyone knows of some common failure of these plastic back 71B?
Edited: 1 Nov 2006, 4:23 p.m.
