Can Debug4x be used for HP 39G/40G development ? Message #1 Posted by Marcus von Cube, Germany on 27 Oct 2006, 4:45 a.m.
The question is already in the subject. Has anybody ever used Debug4x to create a library for the HP 39G or 40G?
I've already asked this question in comp.sys.hp48 and got an answer from Jean-Yves Avenard:
I do it...
Even work on the 40gs ROM with Debug4x
Here is my follow up:
OK, Jean Yves. Can you detail the steps to follow?
A few things come in my mind:
(1) Get the matching emulator ROM and KML (already done)
(2) Get the correct SUPROMxx.* files (either from WSR or the SDK; which is current?)
(3) Get the correct include files (same question as for (2))
(4) Start a project (there is no check mark for the HP39/40 in the project window; what are the settings? I want to create a library.)
(5) Compile
(6) Load the lib into the emulator (I fear that does not work the same way
as for the 48/49 because the machine is so different)
(7) Debug
I'd be glad for any pointers.
You may have noticed that I want to create a communications library for the 39/40. Did you see my post "Creating SysRPL library to exchange data between 39G/40G series and 49G series?" Can provide some help?
Thanks in advance.
Jean-Yves replied that he does not use the Debug4x project feature. He then referred me to his pages at [link]http://etudiant.epita.fr/~avenar_j/hp/39.html[link]
Here is my last post on the topic after which the thread ended:
Jean-Yves,
thanks for the info. I've already looked at your site and downloaded the SDK and other files. The 39G/40G emulator is up and running.
>I do not use the project feature.
Here comes my next question. I compiled the ApletFrame (with the makefile, under CygWin) and the compile went through without problems. I can load the Aplet into the Emulator (via a virtual serial port and Conn3x) and I can start it. What I can't do is debug the aplet with symbols. So how do I setup my environment in Debug4x? Can I compile (and load) from there?
No more info on the topic since then :-(
Can anybody in this community help me further?
Marcus
