Re: Strange HP-67 repair ... Help Please Message #4 Posted by Randy on 23 Oct 2006, 8:42 a.m., in response to message #3 by jbssm
My, that previous response was a great help, wasn't it? Gee, let's see, I have no solution but I'll criticize you anyway. I can get that kind of help from my wife, thank you very much ;^)
Your problem is contact adjustment. The motor start contact is out of position, it is too high. Any case distortion causes the motor to turn on.
Quote: I don't know any way to test them for the correct adjustments with the calculator disassembled
It is very simple. Use a metal straight edge** held across the contacts. Connect one end of the ohm meter to the straight edge, the other to the contact plate. Adjust the same as the 97, tighten until contact is made, then reverse by 1/8 turn. Fiddle as necessary for proper operation. Great fun. Beats removing and installing 8 screws to test each time.
** = Ruler, scale, narrow metal bar, whatever you have that is flat. The bar can be no wider than one contact width.
Edited: 23 Oct 2006, 8:48 a.m.
