Re: HP Portable plus Message #7 Posted by J-F Garnier on 15 Oct 2006, 6:03 a.m., in response to message #6 by Gonzalo Fernandez (Spain)
If the Portable can be run from the external supply, then the charger must be OK because it supplies the Portable as well, and you should see the voltage on the battery terminals . Check again J11, a jumper must be installed in the left position, and the fuse. If there is still no voltage on the battery terminals, check the tracks on the PCB.
J-F
