Re: HP 82161A Battery Pack Message #2 Posted by Marcus von Cube, Germany on 13 Oct 2006, 9:05 a.m., in response to message #1 by Terry Burne
Terry,
new battery packs can be found on eBay. Look for the offerings from waterhosko
If put one of these into my HP-97 which works perfectly.
A do-it-yourself solution could be to wire 4 NiMH AA cells in series (those with soldering tabs bonded to each end) and tape them together. The battery compartment is large enough to hold the pack. Solder the pack to the battery contacts with thin wires or use small clamps to connect it.
Marcus
