Re: Open up a HP42s? Message #2 Posted by Erik Ehrling (Sweden) on 11 Oct 2006, 6:50 a.m., in response to message #1 by Sven Olofsson
I drill out the pins in the battery department and then bend it apart slowly but with quite some force until the lower pins snap. However, it could be a good idea to try cleaning it in an ultrasonic cleaner first, as that might save you from taking it apart.
PS. If nothing else helps - http://www.fixthatcalc.com/
Edited: 11 Oct 2006, 6:52 a.m.
