Re: 19b II Housing Change Possible ? Message #2 Posted by Eric Smith on 3 Oct 2006, 6:20 p.m., in response to message #1 by Daniel Alvarez
To take apart a clamshell (18C, 19B, 19BII, or 28S), you have to peel off labels and drill out a bunch of heat stakes. Once you swap parts, you can glue it back together, but it may not be as "solid" as the original.
I was using an older 28S with a broken battery door in school last spring, because I didn't want to risk losing my good one. I taped the battery door to the calculator. Not pretty, but it worked.
