Re: Half-Dead HP-25, help needed. Message #4 Posted by Hal Bitton on 2 Oct 2006, 10:10 p.m., in response to message #1 by jbssm
One suggestion if I may...
Before you pursue the possibility of a bad chip, just be sure you have exhausted all possibility that the problem is not just poor connectivity at one of the battery contacts, or even internally within the battery pack (I'm assuming that since you are using AA alkalines, the welded on strip that connects the cells in a stock battery pack has been done away with, leaving the spring to connect the two cells). I would polish everything with a pencil eraser (the contacts, both ends of the batteries, and the spring inside the battery pack) and try it again.
My 29c will occasionally exhibit symptoms similar to what you describe, and the above mentioned remedy takes care of it. Hopefully that's all that's wrong with your machine.
Best regards, Hal
