Re: 42s won't turn on Message #2 Posted by Randy on 25 Mar 2006, 10:59 p.m., in response to message #1 by Brian D
In all likelyhood, there is nothing wrong with it. It's just stuck in lah-lah land due to the battery change not being fast enough.
If you had any programs in it, kiss them bye-bye, there is no way to save them at this point.
Here's fix #1:
Press and hold the E+ and XEQ keys down. While holding them down, press and release ON then release the E+ and XEQ. You should see Memory Clear and be back to whatever you were doing before you had to key all your programs back in :(
If that doesn't work, here's #2:
Take the batteries out and touch the two terminals in the calculator at the same time with a coin or straighened paper clip. This will remove the residual voltage on the memory back-up capacitor. Put the batteries back in and enjoy.
And #3:
Leave the batteries out overnight. Same result as #2, it just takes longer.
