Re: How do I open an HP-45? Message #3 Posted by Thomas Radtke on 24 Mar 2006, 3:12 a.m., in response to message #2 by Gerson W. Barbosa
You're right with the positions of the screws. I too think that it is a bad idea to drill through the label as it can be detached from the back cover easily (with some patience). If you warm up the label with a hair dryer, the label can be peeled of. When I did this, I made a bad mistake: I peeled just to the position of the screws but no further. Unfortunately, my screw driver touched the label and bent it a little thus leaving a kink in it:(. Anyway, thats still better than to have holes in it!
I have no answer to the second question. When I got my -45, I already had a self-made replacement battery pack at hand. They are easy to make if you find two thin brass plates that can be angled like the original contact stripes (I can make a picture of it if you need it).
Edited: 24 Mar 2006, 3:17 a.m.
