Re: HP 35 adapter 03502A Message #7 Posted by Dave Shaffer on 24 Mar 2006, 5:10 p.m., in response to message #6 by Michael
Even though you say the calculator works with another charger, you might want to check the ON/OFF switch.
On my '35, the switch is rather intermittent, and one of the symptoms seems to be that the calculator switches ON but then goes off immediately. Wiggling the switch (i.e. jiggling the slider back and forth a bit in the on position) will confirm a problem: the LEDs will blink on and off. Spraying some electronic contact cleaner into the switch (be careful, don't overdo it!) may help.
