Re: screen contrast 41cx Message #5 Posted by don on 23 Mar 2006, 2:08 p.m., in response to message #4 by Vieira, Luiz C. (Brazil)
Thanks, all. Mine is the original screen and tried the battery change routine and there are still problems. The alpha-numeric output is very readable and dark enough.....the problem is there is some faint images behind the alpha-numeric output. This faint output is on the bottom line (shift, bat, ect) and also on the line above that. It is intermitent, not constant.
I actually have 2 41cx's so I can compare the two and am quite sure it is a calculator display problem and not a problem with my expectations.
many thanks
don
