Shortcut to toggle between standard and fix? Message #1 Posted by J.C. Boco on 4 Mar 2006, 4:33 p.m.
Is tehre a way to toggle between standard display and fix (say 3 digits) display?
I have this output and it's hard to read. I use the DET determinate function on
ii j k
3 4 3
5 2 4
The result (I'm making it up) is say
1.235335653ii + 1.and then it runs off the screen. I want to see the j value and the k value.
I figure if I can set it to 3 digit FIX, there is room to see everything. but it's a pain to do that, and almost equally painful to just enter edit mode and scroll to the right.
