Re: help with an HP 48s Message #4 Posted by Randy on 2 Mar 2006, 5:01 p.m., in response to message #3 by bill platt
Cleaning will not help...
I don't like to be a wet blanket here but my recommendation would be "don't bother" - it's not repairable. 99.9% of the 48's I've seen with a battery leak that no longer turn on cannot be repaired due to keyboard damage. The two battery contact areas are open into the calculator, the negative terminal is open into in the case right above the ON button traces. The electrolyte gets into the keyboard circuit and opens the ON trace. End of calculator. Sorry.
PS: Many times it kills the entire bottom row: ON 0 SPC +
Some other points about other topic above:
1) It's safe to immerse/wash HP's so long as the batteries are out of them and you do not reinsert batteries for at least two days after a wet event. You can shake all the excess water out a 48 and dry in a warm place with no problems what so ever. It takes about 24 hours. Most all electronics that are soldered together get washed somewhere along the manufacturing process. No big deal.
2) Never soak an HP for an extended period of time, especially a Pioneer or 48. The keyboard conductors are printed carbon and they can be damaged and even dissolved given the right conditions. The darker plastics used on cases also have a nasty habit of developing
splotchy white areas when left in contact with liquids too long.
Edited: 2 Mar 2006, 5:14 p.m.
