Re: Installing HP-41CX Memory Message #3 Posted by Diego Diaz on 27 Feb 2006, 2:15 p.m., in response to message #1 by SteveH
Hi Steve,
This is a good news, bad news tale...
The bad news are that satndard memory modules (82106A) are only for use in the HP-41C (not CV or CX)
The good news is that your CX is equipped with as much standard memory as it can hold, namely 320 registers.
You may want to increase the Extended memory instead using 82181A Extended Memory modules, you can install up to two of them.
Hope this helps.
Diego.
