Re: HP 15C Memory Allocation Message #4 Posted by Vieira, L. C. (Brazil) on 24 Feb 2006, 12:09 p.m., in response to message #1 by Bill Balme
Hi Bill, all;
This sort of behavior only happens when 0 [f][DIM][(i)] is performed. Registers Ro and R1 in the HP15C are permanent, can never be used with other purposes but store numbers. In fact, they are used as index to access matrix elements.
Beacause 19 [f][DIM][(i)] did not work, I'd suggest two keystroke sequences that might probably solved the problem. The first one would be[f][MATRIX]0 that clears all matrix definitions (dimension 0,0) and data, restoring all registers dedicated to matrices to the 'uncommited register segment'. After that, any register that could be used by matrices would be free for use by programs, though. The other one would be considering the existence of programs and clearing program memory with[f]CLEAR[PRGM] (while in program mode) In both cases, Randy´s precise solution works perfectly fine because all memory is cleared and default status is set. I decided to add this brief because sometimes, even when the problem is solved, the cause may be yet obscure. As I am an Engineer, I am always trying to find the cause so it can be avoided in the future...
Cheers.
Luiz (Brazil)
Edited: 24 Feb 2006, 12:10 p.m.
