Re: HP-29C: another faulty calculator through eBay... Message #6 Posted by Bram on 23 Feb 2006, 10:49 a.m., in response to message #5 by Vassilis Prevelakis
Thank you, Vassilis. Clear picture.
I did exactly the same thing: remove the middle bar, take out the NiCd cells (little force needed) and put 2 alkalines back in. If you use the calculator often and frequently replace the batteries it may be handy to write big pluses and minuses at all proper places in the compartment, and fix the spring with a little piece of tape with 2 sticky sides ('double fix' as it is called in NL).
I have the impression that alkalines are a bit longer and often have a smaller "head". This may cause more tension to the circuit board, so I always put the pack in the calc very carefully.
But, as said before, I hold on to the safe NiCds nowadays.
