Re: solving equations using HP48G Message #2 Posted by Namir on 20 Feb 2006, 10:40 p.m., in response to message #1 by Catherine Green
Catherine,
Afer you nvoke the Solver, you enter the followig equation (the Solver provides the single quotes):
'Y=SQ(3.5*X)*(1-X)*(1-3.5*X*(1-X))'
And then select th OK menu. The above equation defines two variables Y and X. The solver will display these variables. Enter 0 for Y and then enter a guess for X, followed by pressing the SOLVE menu command. Th SOLVER will display the solution for Y=0, i.e. the root.
The above equaion has a root of X=1.
Namir
Edited: 21 Feb 2006, 1:15 a.m.
