HP 41 battery charger and card reader Message #1 Posted by Jan on 13 Feb 2006, 11:15 a.m.
Well, I am glad as a little child that just got a new toy. Today my recently purchased mint-state HP 41CV arrived via the mail, including a card reader with cards and a rechargeable battery-pac with a recharger. The calc I always wanted but which I never could afford when it was still in production. All that for 110 Euros. The calculator naturally works fine, even on the rechargeable pack.
However, the card reader works as well (motor runs) but seems to suffer from a problem common to the 65 and 67 models. There is a greasy substance on the card after passing and sometimes the card gets even stuck in the card reader. I think it is just one of those damn rubber wheels again, I have the same problem with a 67 that I recently obtained. Could anybody confirm my diagnosis?
Then there is something odd about the battery-charger. It is an 82066B, a so called "eurocharger" (that is what can be read on the case). The info on the outer case of the charger also mentions a voltage output of 8VAC. However, when I measure the output voltage directly with an AC voltage meter it gives a voltage of about 14 V (the voltage meter is ok, I did a double check with another meter which also showed the mentioned 14VAC). It seems somewhat strange to me, since it is not plausible that the charger is defect: both calc and accessories were hardly used since the former (1st) owner could not handle the beast very well and soon switched to a Casio.
I read in the archives a little about a similar issue. As I understood it can have something to do with the state of the pack and the pack being insufficiently charged. Besides being also an AC/DC transformer, the pac also acts as a voltage regulator in some versions it was said. Does anybody know some more about this? I would not like to blow up the calcs circuits the first day I have it.
thanks in advance
