Re: Loading Forth ROM into Clonix Module Message #2 Posted by Diego Diaz on 31 Jan 2006, 10:14 a.m., in response to message #1 by Phil Green
Hi Phil,
Please try:
http://www.clonix41.org/Projects/Clonix-41/forth-41.zip
This is the .HEX file to load directly into IC-Prog buffer.
Note that this is compiled with Clonix6P code, therefore, current drain will be higher than the ClonixLP counterpart...
I'll build "LP" .HEX versions for some of these "rare" modules that use pages below #6, namely: Services, Forth, Laitram... it will take a while though. (Really busy nowadays)
Best regards
Diego.
Edited to add: Please remember that Forth ROM as well as any other using page #5 won't work when plugged into 41CX for obvious reasons ;-))
Edited: 31 Jan 2006, 3:33 p.m.
