Re: HP-16C programming challenge - Hamming distance Message #10 Posted by Eric Smith on 27 Jan 2006, 12:53 a.m., in response to message #9 by PeterP
Now you've got me confused. With an eight bit code, there can't possibly be more than 256 codewords (minimum distance 1), and for larger minimum distances there have to be fewer valid codewords.
For instance, for an 8 bit codeword with minimum distance 3, there are
16 valid codes. One set (in hexadecimal) is { 00, 07, 19, 1e, 2a, 2d, 33, 34, 4b, 4c, 52, 55, 61, 66, 78, 7f }.
You can derive different sets, but they all are equivalent to that set with bit permutations and/or XOR by a constant.
Note also that only 7 bits of the 8 are actually needed. Typically the eight bit would be used for word parity, which actually increases it to minimum distance 4. (Confirmed by doing a search for 8 bit codewords with minimum distance 4, which also results in 16 valid codewords.)
I'm not distinguishing "data bits" from "ECC bits". I'm just considering the total number of bits in a codeword. Because an 8 bit codeword of minimum distance 3 (or 4) can have exactly 16 unique values, it can be used to encode 4 bits of data.
I still have not come up with an analytical way to determine the number of codewords for a given bit count and minimum distance. My conjecture was based on output of the brute-force search program, and the patterns for d_min >= bits/2 are not readily apparent, which I think corresponds to the fluctuations in the curves on the ECC page Katie referenced earlier.
Eric
Edited: 27 Jan 2006, 2:59 a.m.
