Re: Most current HP 33s models Message #5 Posted by bill platt on 17 Jan 2006, 11:33 a.m., in response to message #1 by Joe Edwards
You have to test it by operating it through the blister pack. Difficult but not impossible.
You need to run the H.MS DMS routine (check to see if it mishandles negative values) and the Polar-Rectangle routine (test to see if it gets confused going from 90degrees r=1 to X,y and tehn back---if it gives 270 degrees it hjas the bug.
Edited: 17 Jan 2006, 11:33 a.m.
