... the HPILCMD LIF supplied with the HP-75 I/O Utilities.
http://www.series80.org/Misc/HPILCMD.bin
The file in HP LIFUTIL format (DFS to LIF file type preserved xfer type).
You can get the LIFUTIL binary from
ftp://ftp.hpmuseum.org/lif/lifutil
If you run into trouble the easiest way to remove the header is to copy the file skipping the first 0x200 (512) bytes. i.e.
dd if=HPILCMD.bin of=HPILCMD bs=256 skip=2
And then you have to restore the directory info:
HPILCMD -8055 5 256 18
Best Regards
**vp
