Re: Wiring for HPILCOM = HP41 / PC Interfacing Message #2 Posted by Hans Brueggemann [GER] on 6 Jan 2006, 5:34 a.m., in response to message #1 by Christoph Klug
christoph, set the COM1 (or, COM2, if you want) to the following mode : 9600 baud, 8 bits, 1 stopbit, no parity and sw flowcontrol. for the cabling, use a simple 25pin male to 9pin female cable. make sure, that your 82164 is in standard DTE configuration. the 9 pin serial connector on the pc has the following pin-out: 1(in)DCD, 2(in)RXD, 3(out)TXD, 4(out)DTR, 5GND, 6(in)DSR, 7(out)RTS, 8(in)CTS, 9(in)RING.
hope, that helps!
hans
