Re: Opening a HP41 Message #3 Posted by db (martinez, ca.) on 24 Dec 2005, 11:46 a.m., in response to message #1 by Roberto FURLAN
If it was only a little leakage then something is probably just not making contact. You could first try cleaning the contacts and springs again with vinnegar on a Q tip. Sometimes you have to wiggle the battery in place (it moves just a little bit). If the metal on the contact is corroded through; you can get metal contact paint, either in a pen (Katie uses this) or a bottle of "Nickel Print" that you brush on. If you want permanence and beauty; Diego Diaz should soon have the replacement flex connectors that he is having made.
