Re: 12c: Anyone have a good way to program this? :-) Message #13 Posted by tony(nz) on 23 Dec 2005, 5:10 a.m., in response to message #12 by Katie Wasserman
Katie,
For fun, I took your 12C 21 liner below and changed it to do an
insertion sort, appended below.
I needed 5 extra lines and 1 extra register. One could say
this requires 33/21 (approx pi/2) extra resources :-)
Insertion sorting does seem more efficient, even on the 12C.
For example sorting 12 numbers takes about a minute via bubble
sort, whether the numbers are already pre-sorted in ascending
or descending order. The insertion sort is assymetric in that
it takes 12 seconds if the numbers are pre-sorted in ascending
order, and the full minute if they are pre-sorted in
descending order. It appears that the speed/resource trade-off
works in favour of the insertion, even on the 12C.
Personally I still really like your Bubble sort - for me it is
a classic 12C program, and really made me see a whole
new dimension hidden in the 12C.
Bubble Sort on HP12C
Posted by Katie on 26 Oct 2003, 11:11 p.m.
It's easy to use, just fill up registers 0 - n with your data
and call the program with n in the x register.
Keystrokes |Display | Comments
[f][P/R] | |
[f]CLEAR[PRGM] |00- |
[STO][i] |01- 44 12 | i = maximum register
1 |02- 1 |
[STO][n] |03- 44 11 | A: n = 1
[RCL][g][CFj] |04- 45,43 14 | B: y = A(n)
[RCL][g][CFj] |05- 45,43 14 | x = A(n-1)
[g][x<=y] |06- 43 34 | if (x <= y)
[x<>y] |07- 34 | swap x,y
[g][CFj] |08- 43 14 | A(n-1) = x
[RDN] |09- 33 |
[g][CFj] |10- 43 14 | A(n) = y
[RCL][i] |11- 45 12 |
[RCL][n] |12- 45 11 |
1 |13- 1 |
[+] |14- 40 | n = n+1
[g][x<=y] |15- 43 34 | if (n <= i)
[g][GTO]03 |16- 43,33 03 | goto B
2 |17- 2 |
[-] |18- 30 | i = i-1
[g][x=0] |19- 43 35 | if (i = 0)
[g][GTO]00 |20- 43,33 00 | return
[g][GTO]01 |21- 43,33 01 | else goto A
[f][P/R] | |
Insertion sort. 26 lines plus 1 extra register (PMT)
[f][P/R] | |
[STO][PMT] |01- 44 14 | PMT = maximum register
[CLx] |02- 35 |
[i] |03- 12 |
[RCL][i] |04- 45 12 |
1 |05- 1 |
[+] |06- 40 |
[STO][i] |07- 44 12 | 1+i=sublist length
[STO][n] |08- 44 11 |
[RCL][g][CFj] |09- 45,43 14 | B: y = A(n)
[RCL][g][CFj] |10- 45,43 14 | x = A(n-1)
[g][x<=y] |11- 43 34 | if (x <= y)
[g][GTO]22 |12- 43,33 22 |
[x<>y] |13- 34 | swap x,y
[g][CFj] |14- 43 14 | A(n-1) = x
[RDN] |15- 33 |
[g][CFj] |16- 43 14 | A(n) = y
[RCL][g][CFj] |17- 45,43 14 | decrement n
[RCL][n] |18- 45 11 |
[g][x=0] |19- 43 35 | finished?
[g][GTO]22 |20- 43,33 22 | do next sublist
[g][GTO]09 |21- 43,33 09 | continue
[RCL][i] |22- 45 12 | test sublist length
[RCL][PMT] |23- 45 14 |
[g][x<=y] |24- 43 34 |
[g][GTO]00 |25- 43,33 00 | finished.
[g][GTO]04 |26- 43,33 04 | sort next sublist
[f][P/R] | |
Cheers,
Tony
