Re: New solution for the corrosion of HP-41 I/O block. Message #19 Posted by Diego Diaz on 8 Dec 2005, 9:13 a.m., in response to message #18 by Matthias Wehrli
Hi again and a very big thanks to all of you for your kind comments... (Seems you were rigth Bill ;-)
I'd like to clarify that these units are not in production yet. If this was the case I'd have placed a FS ad instead.
These are samples I ordered a few weeks ago and received yesterday for testing. Tests have gone really well. I was the first one to be impressed for the outstanding quality of the board and the accuracy of the tooling job (this was my real concern as tolerances for the I/O interfece are very tight)
The aim of this thread is making myself a clearer idea about the "reasonable" number of units to order mass production. Obviously the final price will depend on that number... the higher the number, the lower the price (ok, you knew that already :-) import taxes will also affect the definitive figures.
The expected range for the final price tag is set between 35 and 45 Eur. As you can see they're not cheap, (more than $1000 just for processing and tooling... three samples!!) that's probably why no-one had decided re-manufacturing them before... that, and the difficulties in find a high quality manufacturer willing to accept so small a run orders... most HI-Tech manufacturers of Flex-PCB's do not accept orders below the thousand units.
Regarding availablity, they can be ready to ship by early Feb. I'll place the corresponding FS ad with the usual info in this site as I got them on hand.
Again thanks for your interest and best wishes for this Xmas season from the (now sunny :-) Canary Islands.
Diego
