Re: HP-21 keybord malfunction Message #2 Posted by hugh steers on 5 Dec 2005, 10:12 a.m., in response to message #1 by Mike (Stgt)
hi mike,
try this, it has worked for me on several woodstocks. take the machine apart and separate the circit boards. you don't need to dismantle the keyboard. the idea is co tony duell.
find a fine wire brush and poke it into the holes in the back of the keyboard circuit. if you look closely you might see some green inside the holes. ive seen this on several and its small amounts of corroded copper and possibly the problem.
try pressing the key at the same time as working the brush. this squeezes the contact against it and can help as long as you're not too violent.
hope this helps,
Edited: 5 Dec 2005, 10:16 a.m.
