Re: A way to polish aluminium Message #12 Posted by David Smith on 24 Nov 2005, 10:42 p.m., in response to message #1 by inaki
The only way to remove an engraving from anything is too remove enough material from the surface until you reach the depth of the engraving. Your best bet would be to remove the bezel (can be hard to do without bending it), The bezel is held down with double sided sticky film. I have used a stong thread soaked in UnDu (heptane).
Next sand the surface down with coarse sand paper. Lay the paper on a hard, smooth surface and work the bezel back and forth. Be careful no to snag and bend the bezel. When you get close, switch to ever finer grit. To get a good final surface you may need to polish it shiny with Flitz, etc then use steel wool or ultragrit sandpaper or a fine wire brush to apply the final brushed aluminium grain pattern.
I bet it will never look right.
