Re: HP15C - differences in displays Message #2 Posted by Eric Smith on 22 Oct 2005, 10:08 p.m., in response to message #1 by Artur - Brasil
Could you please post the part numbers of the chips in both calculators, as well as the part numbers of the circuit boards (typically 5180-xxxx, 00xxx-600xx, or 00xxx-800xx)? If it's not too much trouble, high-res photos of both sides of both boards would be nice. I'm collecting info for my Voyager internals web page, and would like to link each entry to example photos.
I'm guessing that your 15C has the 1LQ9-0325 processor and uses a 4:1 multiplexed display instead of the older 2:1. The 4:1 mux only needs about 29 contacts (25 segments x 4 backplanes), vs. about 52 for 2:1 mux. The drawback of the higher mux ratio is that the contrast isn't quite as good.
Unfortunately the displays aren't interchangeable, as I's sure you've realized. But it shouldn't be too hard to find a 12C of comparable vintage to the 15C, which should then have the 4:1 muxed display.
Best regards,
Eric
Edited: 22 Oct 2005, 10:57 p.m.
