Re: Identifying HP-71B modules Message #3 Posted by Frank Wales on 16 Oct 2005, 4:07 p.m., in response to message #2 by Tony Duell
The DHSS module turns the HP-71 into a terminal for a one-off file tracking database system that was used to track paperwork within several hundred DHSS offices from about 1985 to about 1992.
Every document had a barcode (type 2 of 5, I think) on it, and possible locations within each DHSS office were also coded. Moving a document required the user to scan the document barcodes, and the destination code, which updated the database. Users could also enter keywords, such as claimant name, on the HP-71 to search the database to find the location of the relevant document. I think a simple messaging system was also included, but I might be misremembering.
The database system was custom-written software on a PC running Concurrent CP/M (or maybe MP/M). The HP-71s were networked via HP-IL, and connected to the PC through an RS-232 interface. Because of technical restrictions, one HP-71 was designated as a master, and dedicated to handling the communication between the PC and the network. Up to 42 terminals per network were required to be supported, for reasons which later turned out to be related more to Douglas Adams than actual requirements; I think the maximum installation in any one office was about 30.
All the software was custom-written, and used a wholly custom communication protocol and database query language on the RS-232 link. Without the back-end database, RS-232 link, and separate HP-71s running both master and terminal ROM modules, the HP-71 side is basically useless.
How do I know all this? I was one of the developers of this system when I worked at Zengrange, which supplied the HP-71 software and all the barcode wands.
As a piece of trivia, this is the project for which Zengrange developed Zenwand; without the need to somehow have several thousand barcode wands for HP-71s, Zenwand wouldn't have happened. Once we decided to make a wand for the HP-71, we then figured out what additional functionality, beyond that strictly required for the DHSS system, would be useful to end users. Hence the barcode printing software, auto-discriminating barcode scanning, check-digit utility functions and other stuff that's in the wand.
And before you ask: no, I don't have any documentation or other information about the system beyond what I remember from 20 years ago.
