HP-12C: Corrosion on Negative Terminal Message #1 Posted by Mike Brady on 11 Oct 2005, 9:13 p.m.
Does anyone have a solution for preventing copper oxide corrosion from developing at the negative battery terminal (the platted plunger type contact). I'm guessing the copper oxide is caused by cathodic corrosion which is developing between the two different metals of the battery's negative surface and the calculator's non-tinned negative terminal.
