Re: Help? Message #5 Posted by Eric on 23 Oct 2005, 8:14 p.m., in response to message #4 by Chris B.
Thanks a bunch- I seriously appreciate it... I was able to get the battery cover off knowing what the cover looked like and knowing where the adhesive was- it wasn't as bad as I expected. I'd just rather be safe than sorry.
I know the Xpanders have a bug where if the battery is totally discharged it won't charge them up at all.
I also understand that you *CAN* replace the rechargeables with some standard AAA's, but not to plug it in or else it will charge the non-rechargeables.. Right?
So, what's the best batteries to run? The batteries in there looked pretty odd- no nipple on the + side of the battery..
Thanks again for all your help!
Eric
