Re: HP 21 display repair Message #4 Posted by David Smith on 2 Oct 2005, 3:27 p.m., in response to message #1 by Harry (Germany)
The display module uses chip-on-board technology where the individual LED chips are attached to the board and wire bonded down This makes the LED module like a big integrated circuit chip. You can pretty much forget sawing the thing in half and patching it back together... unless you have a wire bonder, chip bonder, full chip doctor setup, etc... but if you had these you probably would not have asked the question. Best to find a machine with a bad ACT or RAM chip, and salvage the display module.
