Replacement batts (was: HP 9114B Batteries. Help !!!!) Message #9 Posted by Vieira, Luiz C. (Brazil) on 28 Sept 2005, 2:48 a.m., in response to message #1 by Gileno
Hi Gileno, guys;
these are the pictures I got: (click any to enlarge)
short.jpg)
Specs are visible and readable, though. Unipower battery ID is UP628. The National LCR6V2.4P is the one that came with the 9114B I have (thanks, D.M.). Physical dimensions for UP628 match LCR6V2.4P except for the largest dimension: UP628 case is about 2mm `taller`. UP628 contacts are also in different orientation and position, so I had to solder another wire for negative terminal. Anyway, it fits fine in original 88014B (battery pack).
Gileno, if you do not find it in local suppliers, let me know. Mine was brought from Sao Paulo, and I do not know the original supplier address, only the local supplier. If you do not succeed finding it, let me know.
Cheers.
Luiz
Edited: 28 Sept 2005, 2:52 a.m.
