Re: Alternative HP-42S Manual (Another version) Message #7 Posted by Vieira, Luiz C. (Brazil) on 6 Aug 2005, 4:23 p.m., in response to message #6 by mbrady
Hi;
forgive me if I`m asking silly questions, I just want to help if I can.
Do you have the Acrobat Reader already installed in your computer? If not, you cannot actually read a .pdf (pdf stands for Portable Document File);
have you tried to download the file prior to read it? In some cases, the www viewer (an additional plug in) may not be present, and the document shows blank;
when you wrote "bringing up the 42s manual's *.pdf file", which file are you actually reffering to?
Please, I`m not the author, I just want to help. So far I have not read about others trying to open without success, I myself could download and actually open the document. Would you, if applicable, briefly describe what did you do in order to view the file?
Thanks and forgive me if answers are obvious or if questions do not actually reffer to your needs.
Luiz (Brazil)
Edited: 6 Aug 2005, 7:47 p.m.
