Re: Best way to open a modul-housing Message #4 Posted by Miki Mihajlovic on 23 July 2005, 1:48 p.m., in response to message #3 by Wilhelm Loidl
I find that using long nose pliers (nozzle pliers) works best for me. This is the trick Diego Diaz told me about. The longer and thinner the nose the better. Put the nose of pliers in the module opening, and CAREFULLY open the pliers while at the same time applying counter pressure with your fingers opposite to pliers action (for balancing) until the module cracks. In 95% of cases the module opens flawlessly.
