May I suggest...(was: Tips on Getting Publishing Permission Message #11 Posted by Vieira, Luiz C. (Brazil) on 16 July 2005, 9:50 p.m., in response to message #1 by Howard Owen
Hi Howard, guys;
Howard wrote: Quote: HP has made most of the source documents referred to free to redistribute
As the codes from HP are free for redistribution, I'd volunteer myself to take the scanned images where the original HP codes are shown, cut them, úse an OCR to generate an ASCII equivalent text and send it back to you so you could release the codes in an original PDF file with the necessary comments of what can be done with the programs or the keystrokes, if applicable, without using the original text from the book. We have many known contributors that are experts on dealing with HPIL that could also add some original remarks, making this suggested original PDF even better. I guess you could also refer to both HP and the book as the sources, plus the names of all contributors who added something to the final text and McGraw Hill publishers will not be able to complaint for that (hope they are not reading this...)
I am trying to finish some repairs in some HP calculators with me (one CX mainboard that belongs to M.B., one HP29C that belongs to R.T. and two HP41 plus three HP25 that belong to J.E.), and I believe I'm having time to generate these listings when taking a time to think of what to do next (I also have a few other HP calculator related activity, but they are not repair activities). If you actually can do that - use an OCR and generate typed text or simply key the programs in and save the final listings somehow - and you are willing to go ahead, wow! We will all be grateful. Otherwise, have you found yourself needing some help, let us know.
Best regards.
Luiz (Brazil)
