Test Message #3 Posted by Paul Brogger on 5 July 2005, 5:50 p.m., in response to message #1 by Natasha
Try pinching the calculator firmly, front-to-back just below the display on the right side.
If the keys work while the calc is being squeesed in this manner, you've got a common problem: an atrophied rubber pressure strip that is meant to maintain contact between the keyboard assembly and the main printed circuit board.
It's a relatively easy fix -- though perhaps more than many would care to attempt. If you don't want to try yourself, chase down Randy Sloyer (www.fixthatcalc.com).
Good luck, and let us know how it comes out.
